ich habe auf der MS2 Extra site folgenden text gefunden:
Also macht es für die MS1 keinen Unterschied für einen zwei Zylinder ob ich nun ein 36-1 Wheel habe oder einfach nur einen Zacken auf der Kurbelwelle ?systems, for example, use a 60 tooth crank trigger with two missing teeth.
MS1/Extra handles these types of distributor based ignitions with a wheel decoder that works as a front end to the distributor. The wheel decoder identifies which teeth on the wheel are functionally equivalent to distributor trigger points, and tells the distributor timing algorithm when to start its countdown. So on a six cylinder engine, the distributor timing algorithm would get triggered three times per crankshaft revolution. The distributor timing algorithm does not take the other teeth into account, as the wheel decoder could effectively make a 60-2 wheel look like a three tooth crank trigger as far as the distributor timing algorithm is concerned.
Ami 8 / Horst meinte doch mal das sein Motor nach Installation eines 36-1 Rades wesentlich dynamischer auf das Gas reagieren konnte.
Max
