POE 2: Forbidden Rites Event Is Now Live! IGGM Helps You Get Ahead Quickly!
Verfasst: So Sep 20, 2026 4:22 am
POE 2 Forbidden Rites event is already live. Players create a new character in a separate economy and push from campaign into endgame. If you want your build online quickly and to keep pace with the event, Currency matters more than usual: almost every gear upgrade, affix change, and key setup improvement depends on a steady supply of it.
How Currency Decides Build Upgrade Speed
In Forbidden Rites, Ritual content keeps offering Rare gear and exchange resources, but turning drops into real power still relies on Currency. Using it to finish base selection, raise rarity, reroll or lock affixes is what takes an item from “barely wearable” to something that can handle the next stage of content.
Chained boss Rituals, the reworked Trial of Chaos, and endgame map pressure all push you to improve survivability and damage. A build does not come online in one step. Each of those steps spends Currency. When reserves run dry, you often stay on transition gear and farm in circles; when reserves are healthy, you can replace weak slots on schedule and test your archetype sooner.
For players with limited time, that gap is especially clear. In the same session length, one person is upgrading the build while another is still stuck chasing basic materials. Currency is not power by itself, but it decides how fast you can turn event opportunities into character growth.
Why the Early League Needs Larger Reserves
Forbidden Rites runs for months, yet efficiency in the first two weeks shapes the whole cycle. Prices and drops move quickly in a fresh economy, and key upgrades completed early often prevent bottlenecks later. Trying different skill setups, or switching focus between Ritual and endgame, increases consumption further. At that point, being able to cover a shortfall in one go is worth more than scattered farming.
Why IGGM Matters for Getting Currency Quickly
If you would rather spend time refining the build and learning the event systems than grinding basic Currency for long stretches, IGGM offers a more direct path. The platform makes it practical to obtain large amounts of POE 2 Currency quickly, with a clear process and relatively fast delivery. It fits moments when you need an immediate top-up—before a difficulty jump, or when several core items must be upgraded in a short window.
That way you are less likely to pause a build plan because materials ran out, and you can schedule Rituals, trials, and endgame goals with fewer interruptions. For anyone who wants steady growth through the event league, this kind of support cuts a lot of early friction.
The Forbidden Rites window is open. Build strength still comes from setup and play, but Currency decides how fast that setup can come together. When you need to move faster, visit IGGM for the Currency you need and keep your character’s upgrades on track.
In addition, you can learn more about the latest version updates from recent articles—such as "Path of Exile 2 Patch 0.5.5: Gas Grenade Pathfinder Build (All-New Version) & Crafting: How to Reach the Top?"
How to buy POE 2 Currency at IGGM.com?
1. Select Runes of Aldur SC/HC or Standard/Hardcore and Forbidden Rites SC server;
2. Add currency one by one to cart and click checkout; Or Buy Now directly;
3. Fill in user infomation and delivery infomation, check all right;
4. Choose a payment method, enter the 8% off code: FR8, and then click Pay Now.
Forbidden Rites is both a brand new challenge and an important stage before the 1.0 release. Preparing your resources in advance will allow you to enjoy this months-long league more efficiently once the event begins. Head over to IGGM now to get fully prepared for the upcoming Forbidden Rites!
