Seite 3 von 6
				Re: FreeEMS - Open Source Motorsteuergerät
				Verfasst: Sa Jun 22, 2013 1:59 pm
				von Fearless
				LOL! Nice
 Give us a higher res image of your 25mm board, if you don't mind, I'm curious, morbidly so.
But big question: Why not just design an entire board? What's the point in all the effort to DOWNGRADE the software from OEM to M$2 and keep highly limited OEM hardware in between it and the engine? Seems pointless. Unless you're going for stealth?
Fred.
				Verfasst: Sa Jun 22, 2013 2:10 pm
				von KLAS
				Fearless hat geschrieben: Unless you're going for stealth?
thats the general reason in Germany.
making a special PCB only makes sense if you find enough people who wants the same
				Verfasst: Sa Jun 22, 2013 3:09 pm
				von tooly
				Fearless hat geschrieben:LOL! Nice
yes i could do
but why
no one need it
Fearless hat geschrieben:What's the point in all the effort to DOWNGRADE the software from OEM to M$2 and keep highly limited OEM hardware in between it and the engine?
i also downgrade to freeems
the board could be look like this
				Verfasst: So Jun 23, 2013 2:02 am
				von Fearless
				tooly hat geschrieben:
yes i could do
but why
no one need it
Grossly wrong. Every time you take a random engine and put it in a random chassis, that's exactly what you need. Hence so many standalone manufacturers, MS's popularity, and FreeEMS's level of support.
tooly hat geschrieben:i also downgrade to freeems
Yes, you certainly do, no argument there. Why the downgrade was the question.
tooly hat geschrieben:the board could be look like this
Neat, but sooooooo niche
 If you send me something, it will at least have to be usable by plugging into USB for power or something like that.
Fred.
				Verfasst: So Jun 23, 2013 11:41 am
				von Metaworld82
				Hey Tooly,
I still got a  PE Micro USB BDM Interface too get the Freds Serial Monitor on your new Baby if you want to Play with this new Project. I just read the Forum of DIYEFI. First what we Need for us should be a prober Hardwareboard for fast Development.
I´m  interessted in this Projekt too.
@Fred. Nice work for one man power!!
				Verfasst: So Jun 23, 2013 12:41 pm
				von Fearless
				Andy (DeuceEFI) can ship you a USBDM (open sauce/sores/source) for $32 US + shipping, if you need one:
http://www.coolefi.com/usbdm.php
That can also let you upgrade your serial monitor on your MS2 stuff to a proper one usable by other tools. I'll attach that S19 to this post for future reference.
In terms of FreeEMS as it is, no boards are really required, and supporting board developers is just a drain on the limited resources. However, for adding this CPU to the option list, I'd need a dev board that I an access pins on, and load code to through USB.
Thanks Metaworld82, it's been a long hard road, and it's far from over yet, but the payoffs are starting to roll in
Fred.
				Verfasst: Mi Jun 26, 2013 8:13 pm
				von tooly
				Fearless hat geschrieben:Grossly wrong. Every time you take a random engine and put it in a random chassis, that's exactly what you need.
why not use a dme with this nice hardeware inside
this is reel active recycling
 Fearless hat geschrieben:Neat, but sooooooo niche
if you hack a motronic 3.x you got up to 12 output channels,up to 8 input channels, you got a good connector,...
you got an freeems schematic as pdf?
i cant find one
just this ravage.pdf
Metaworld82 hat geschrieben:I still got a  PE Micro USB BDM Interface too get the Freds Serial Monitor on your new Baby if you want to Play with this new Project.
i got an usb bdm too
thomas
				Verfasst: Do Jul 11, 2013 1:57 pm
				von Fearless
				Because your OEM hardware is severely limited in many ways, includes stuff that isn't needed, and fails to include stuff that is. But whatever floats your boat, versatility is king
There is no "FreeEMS schematic", FreeEMS is firmware, schematics are for hardware which interface that firmware with a particular set of signals and an engine of some sort. RavAGE.pdf is your best bet. Jaguar's schematics are similar and also useful.
Sorry for the delay, I was away from home for two weeks helping a race team who were using FreeEMS to compete internationally. FreeEMS performed flawlessly (using a Jaguar 0.4-alpha and customised firmware), however the car suffered a driveline failure putting it out of the race.
Fred.
				Verfasst: Di Aug 06, 2013 9:30 pm
				von tooly
				damit das hier mal weitergeht und es einfacher wird das ganze zu testen
hab ich angefangen eine 40-6pin-adapterplatte für ein msv3.0 board zu frickeln
http://forum.diyefi.org/viewtopic.php?f=9&t=2229
				Verfasst: Di Aug 06, 2013 9:51 pm
				von Fearless
				Nice work, tooly!
				Verfasst: Mi Aug 07, 2013 9:43 am
				von HHTC
				brauchen wir nur noch die passende Firmware und die Umbenennung des Forum in Motorkontrolle...
				Verfasst: Mi Aug 07, 2013 11:15 am
				Na dann los
 Das klingt interessant.
				Verfasst: Mi Aug 07, 2013 11:47 am
				von Fearless
				HHTC hat geschrieben:brauchen wir nur noch die passende Firmware und die Umbenennung des Forum in Motorkontrolle...
LOL! Firmware is close-ish, rest of ecosystem is a bit of a mess, as tooly will soon find out. It's all close, though.
				Verfasst: Do Aug 08, 2013 8:12 pm
				von tooly
				hab das layout jetzt fast fertig
hat jemand bedarf an einer unbestückten ungetesteten platine?
dann weiss ich ob ich nur 1-2 für mich oder gleich mehr machen lasse
				Verfasst: Do Aug 08, 2013 8:16 pm
				von Fearless
				Me please! I may need to do some work to make it work at all with the different CPU. And if not, it'll be a handy dev board for me. Thanks for your work!
